Component: LED (LES, Panel) ()
Revision as of 17:53, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.3
Category
LED (LES, Panel) component
Panel lamp for a LES bulb. Colour can be changed in component properties.
Please click here for the component source code: FC_Comp_Source_lamp_les.fcfx
LED Resistor Calculator Tool
Fc9-type-5-icon.png Connection
Chip pin to which the LED is connected.
Fc9-type-16-icon.png Polarity
Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> True color
Fc9-conn-icon.png Simulation
Fc9-type-1-icon.png Color
The color of the lmap when truned on. When turned off, it will use a much darker shade of the same hue.
Fc9-conn-icon.png Label
Fc9-type-16-icon.png Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Fc9-type-10-icon.png Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color of the labels text.
Fc9-type-15-icon.png Scale
Sets the basic size (text height) of the labels.
Fc9-type-7-icon.png Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Fc9-type-16-icon.png Position
Position of the label relative to the component.
