Component: Potentiometer (Panel) ()
Version 1.4
Category
Potentiometer (Panel) component
Analogue potentiometer with chicken head style pointer.
Note: The default Vref properties for AVR/Arduino is AREF. If there is no voltage being applied to the AREF pin, then you must change Vref option from AREF to AVCC
Please click here for the component source code: FC_Comp_Source_pot_Panel.fcfx
FC6 Icon.png Potentiometer Example
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-7-icon.png Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
