Component: Potentiometer (Trimmer) ()
Revision as of 08:27, 21 December 2022 by MartinW (talk | contribs) (→Potentiometer (Trimmer) component)
| Author | Matrix Ltd |
| Version | 1.4 |
| Category |
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
Note: The default Vref properties for AVR/Arduino is AREF. If there is no voltage being applied to the AREF pin, then you must change Vref option from AREF to AVCC
Please click here for the component source code: FC_Comp_Source_pot_Trimmer.fcfx
