Component: Slider control (Advanced Shapes)
Revision as of 17:54, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.1
Category Advanced Shapes
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
Please click here for the component source code: FC_Comp_Source_slider.fcfx
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications. Meters
GetValue
Gets the current value of the slider. This will be within the range set by the SetRange macro.
- FLOAT Return
SetValue
Set the current value of the slider. This will override any value set by using the mouse.
- FLOAT Value
The value to set.
SetInteractive
Set whether the mouse can be used to change the slider value.
- BOOL Enable
Set true to allow clicks to set scale
ShowScale
Set whether graduated marking are shown along the length of the slider.
- BOOL Show
True to show scale, else false
SetRange
Set the minimum and maximum values that can be shown on the slider.
- INT Min
Min (start) value
- INT Max
Maximum (end) value
