| Author
Matrix Ltd
| Version
1.0
| Category
Segment
7Segment (74HC595) component
Seven segment display using 74HC595 serial to parallel shift register. Requires three standard output pins to drive the shift register. Shift registers can be chained together to drive up to six individual 7-segment displays.
Please click here for the component source code: FC_Comp_Source_74HC595_7SEG_Hex_Driver_2dgi.fcfx
ShowDigits
| Set the number and decimal point to be displayed in the given digit of the display.
- BYTE
Value0
| The number value to set the digit to (0...15), 16=Clear
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Value4
- BYTE
Value5
- BYTE
DecimalPoint
| Bit field containing the states of the decimal points.
ShowSegments
| Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
| Which of the digits to change. (0...5)
- BYTE
Segments
| The binary segment value to display, 0b1 = Lit, 0b0 = Not Lit
ShowDigit
| Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
| Whether to show the decimal point.
Number 7Segs
Display Type
| Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
| Show segment name labels overlayed over the component.
Data Pin
| Data Pin connection to the first 74HC595 chip
Clock Pin
| Clock Pin connection to all the 74HC595 chips
Latch Pin
| Latch Pin connection to all the 74HC595 chips
Colours
LED Colour
| Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Colour
| Color of the plastic casing containing the LEDs.
Label Colour
| Color for the optional LED segment labels.
