Component: Infrared Array AMG88xx (Light)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs)
Category Light
Infrared Array AMG88xx component
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection.
Please click here for the component source code: FC_Comp_Source_AMG88.fcfx
Fc9-comp-macro.png SetMovingAverageMode
Set the moving average mode on or off.
Fc9-bool-icon.png - BOOL Mode
0 = Off, 1 = On
Fc9-comp-macro.png ClearInterrupt
Clear any triggered interrupts
Fc9-comp-macro.png SetInterruptMode
Set the interrupt to either absolute value or difference mode
0 = Difference / 1 = Absolute
Allows the interrupt pin to be enabled or disabled.
0 = Disabled / 1 = Enabled
Fc9-comp-macro.png SetInterruptLevels
Set the interrupt levels. Interrupt when going above High or interrupt when going below Low.
Fc9-f32-icon.png - FLOAT High
Range: -1023 to 1023
Fc9-f32-icon.png - FLOAT Low
Fc9-f32-icon.png - FLOAT Hysteresis
Range: -1023 to 1023 ( Recommend 0.95 * High )
Fc9-comp-macro.png SamplePixels
Reads Infrared sensor values
Fc9-comp-macro.png ReadThermistor
Reads the onboard thermistor Returns the temperature in degrees Celsius as a floating point value
Fc9-comp-macro.png ReadPixel
Reads the temperature of a single pixel value from the last SamplePixels call.
Fc9-u8-icon.png - BYTE Index
Pixel to read. Range: 0 - 63
Fc9-comp-macro.png Initialise
Sets up the I2C interface and initialises the sensor.
Fc9-type-21-icon.png Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
