Component: Bluetooth (ESP32 SPP) (Wireless)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs)
Category Wireless
Bluetooth (ESP32 SPP) component
Bluetooth slave component designed to run on a ESP32 providing legacy SPP functionality. BT Legacy functionality must be switched on via the sdkconfig file.
Please click here for the component source code: FC_Comp_Source_Bluetooth_ESP32_SPP.fcfx
A simple example file showing how to send and receive data using the ESP32 Bluetooth Serial Port Profile.
FC6 Icon.png ESP_BT
The SPP legacy bluetooth mode must be enabled in the ESP32 config file to allow SSP to work. For details please see this forum topic.
For problems sending strings or missing data bytes, please see this forum topic.
Fc9-comp-macro.png ReceiveByte
Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured
Fc9-u16-icon.png - UINT Timeout
Number of ms to wait for incoming data
Fc9-comp-macro.png SendString
Sends a string to the Bluetooth serial connection
Data Array to send
Fc9-comp-macro.png CheckConnectionStatus
Checks to see if the Bluetooth device is connected. Returns 1 if connected.
Fc9-comp-macro.png ReceiveCount
Collects the number of bytes currently stored in the receive buffer.
Fc9-comp-macro.png ReceiveArray
Attempts to receive an array of bytes from the bluetooth serial port. Returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
Buffer to place received data into
Fc9-u16-icon.png - UINT MaxBytes
Max number of bytes to try and read within the time
Fc9-comp-macro.png SendArray
Sends a byte to the Bluetooth serial connection
Data Array to send
Fc9-u16-icon.png - UINT NumBytes
Number of bytes to send
Fc9-comp-macro.png SendByte
Fc9-comp-macro.png ReceiveString
Fc9-comp-macro.png Initialise
Starts up the Bluetooth communications SPP service.
Fc9-type-10-icon.png Device Name
Sets the Bluetooth device friendly name
Fc9-type-21-icon.png Receive Buffer
Configures the size of the receive buffer in bytes to store incoming data until we are ready to receive it.
Fc9-type-7-icon.png Data Receive Interrupt
Fc9-type-16-icon.png Verbose Debug
When enabled debug messages will be placed onto UART CH1 which is generally connected to via a Serial to USB IC to pipe messages back to the host PC.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png COM Port
Selects which port to communicate with, only lists ports which are currently available.
Fc9-type-7-icon.png Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Fc9-type-14-icon.png Baud
Baud rate passed to the COM port to control the rate of data.
