Component: Circular Buffer Free Sim (Buffer)
| Author | Matrix Ltd |
| Version | 1.5 |
| Category | Buffer |
Circular Buffer Free Sim component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data byte storage. Useful when used with a comms component to capture data as it comes in ready for processing when we have time. Also features macros to allow you to check for specific incoming responses such as "OK" or "ERROR".
Please click here for the component source code: FC_Comp_Source_CircularBuffer_FreeSim.fcfx
| GetIndexedByte | |
| Gets the value of a single byte at a known location in the buffer. Leaves the buffer contents and pointers untouched. | |
| address | |
| GetNumberBytes | |
| Returns the number of valid data bytes currently inside the buffer. | |
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
| PeekByte | |
| Reads the next available byte from the circular buffer without advancing the current index, Returns 255/512 if the buffer is empty. | |
| GetByte | |
| Reads the next available byte from the circular buffer, Returns 255/512 if the buffer is empty. | |
| FlushBuffer | |
| Clears the contents of the buffer and re-initialises the index locations. | |
