Component: Interlace (DSP Operators)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.2 |- | width="20%" style="color:gray...")
Version 1.2
Category DSP Operators
Interlace component
Allows multiple input buffers to be interlaced together into a single output buffer. Useful for combining several streams together for sending out via communications or storing.
Please click here for the component source code: FC_Comp_Source_DSP_Interlace.fcfx
Interlace
Collects a single value from each of the connected input buffers and places in order into the output buffer.
InterlaceArray
Repeats the interlace function as many times as set in the data count property.
Connect To 0
Connect To 1
Buffer Size
Buffer Type
Sets the buffer data type.
Interlace
Number of Inputs
The number of inputs the multiplexer can switch between.
Data Count
Number of complete output packets the buffer can store. Default 1.
Output Mode
