Component: Switch (BL0145) (E-blocks 2)
Revision as of 14:40, 16 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
Switch component
A set of 8 push switches that can be connected to an E-blocks 2 upstream board via a port connector. Switches are wired in an active high configuration.
Please click here for the component source code: FC_Comp_Source_EBlocks2_Switch_BL0145.fcfx
Fc9-comp-macro.png ReadState
Read the state of the switch at the given index.
Fc9-u8-icon.png - BYTE Index
The switch to read the status of.
Fc9-comp-macro.png WaitUntilHigh
Pause the program until the switch at the given index is turned on.
Index of the switch to wait for.
Fc9-comp-macro.png ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
Fc9-comp-macro.png WaitUntilLow
Fc9-type-16-icon.png Input Mode
Choose how your switches are connected. PORT = Single port byte for all switches - pins are allocated in sequence from pin 0 - X Custom = Individual pin by pin connections
Fc9-type-19-icon.png Port
