Component: LCD (Adafruit, 16x2) (Alphanumeric)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.8 |
Category | Alphanumeric |
LCD (Adafruit, 16x2) component
Adafruit OLED LCD display capable of displaying 2 lines of 16 characters.
Please click here for the component source code: FC_Comp_Source_LCD_Adafruit_OLED.fcfx
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
Clear |
Clears the entire contents of the display. | |
Return |
PrintString |
Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
Text |
Return |
PrintAscii |
Takes the ascii value for a character and prints the character | |
character |
Holds an ascii value. | |
Return |
PrintNumber |
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
Number |
Return |
ClearLine |
Clears a single line on the display before moving the cursor back to the start of the line to allow new data to be displayed. | |
Line |
Return |
Cursor |
Moves the cursor on the LCD Display | |
x |
y |
Return |
ScrollDisplay |
Scrolls the display left or right by a number of given positions. | |
Position |
Holds the number of positions to shift the display | |
direction |
0 = left, 1 = right | |
Return |
Start |
Startup routine required by the hardware device. Automatically clears the display when complete. | |
Return |
