Component: Map Function (Calculation)
| Author | medelec35 |
| Version | 2.0 |
| Category | Calculation |
Map Function component
The map function is intended to change one range of values into another range of values. For example. Output from a temperature sensor is in centigrade. you can map it to give the result in Fahrenheit. To do that set: InMin to 0, InMax 100, OutMin to 32 & OutMax to 212
Please click here for the component source code: FC_Comp_Source_Map-Function.fcfx
| Properties |
