Component: One Wire (Comms: Interface)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category Comms: Interface
One Wire component
Low level routines for controlling or interacting with a standard one wire interface.
Please click here for the component source code: FC_Comp_Source_One_Wire.fcfx
Device Scanning
To get started with one wire devices it is often useful to collect the unique device serial number for each and every one wire device you are going to connect to your bus.
For example if you have a bus with two temperature sensors connected it is useful to know which sensor is which. Sensor A is monitoring temperature A and sensor B is monitoring temperature B. The only way to tell which is which is to use the serial number.
Here is a program that scans for devices on a one wire bus and outputs the device count and serial numbers using a LCD.
FC6 Icon.png One Wire Device Scan LCD
Here is the same program but this time the device count and serial numbers are output using a UART such as on an Arduino or ESP32.
FC6 Icon.png One Wire Device Scan Serial
To use the examples simply connect a single device to the one wire bus and make a note of the reported serial number.
This serial number can then be entered into the specific one wire component and used to ensure you are communicating with the device you think you are.
A pull up resistor of between 1K and 10K is required between the data I/O pin and VCC.
Further Examples
The One Wire component is a key building block required by a number of other components. Some of which are included below.
Example One Wire comms component being referenced by several specific One Wire device library components.
Fc9-comp-macro.png ReceiveByte
Fc9-comp-macro.png TransmitByte
Transmit a byte to the one wire bus a bit at a time
Fc9-u8-icon.png - BYTE Command
Fc9-comp-macro.png SkipROM
Performs a bus reset and the sends the SkipROM command byte
Fc9-comp-macro.png BusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
Fc9-comp-macro.png MatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
Fc9-u8-icon.png - BYTE FamilyCode
Fc9-u8-icon.png - BYTE SerialNumber
Fc9-comp-macro.png ScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
Fc9-comp-macro.png GetDeviceCount
Fc9-comp-macro.png GetIDByte
Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
Fc9-u8-icon.png - BYTE Device
Device ID - Range: 0 - NumDevices - 1
Fc9-u8-icon.png - BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
Fc9-comp-macro.png Initialise
Sets up the 1-Wire output pin ready for communications.
Fc9-type-5-icon.png One Wire Pin
I/O pin used to host one wire bus.
Fc9-type-21-icon.png Max Devices
Controls the maximum number of devices that can be detected during a ScanBus. For each additional device we require 8 bytes to store the ROM ID. Default: 8 = 64 Bytes of RAM
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Lists all the current injector components available on the user's panel
