Component: PWM (CAL) (Misc)
Author | Matrix TSL |
Version | 2.2 |
Category | Misc |
PWM component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Pulse Width Modulation peripheral.
Please click here for the component source code: FC_Comp_Source_PWM.fcfx
GetValue |
Returns Named property Value | |
Name |
Return |
ChangePeriod |
Change the Period (and prescaler) for this PWM Channel | |
period |
period value PIC/AVR: 0-255 16-bit PIC: 0-65535 | |
prescaler |
prescaler 1,4,16,64 | |
Return |
Disable |
Disable this PWM Channel | |
Return |
SetDuty8Bit |
Set the Duty cycle (0-255) for this PWM Channel | |
duty |
duty value 0 - 255 | |
Return |
Enable |
Enable this PWM Channel | |
Return |
ChangeFrequency |
Advanced function for the ESP32 hardware to set the PWM output frequency. | |
Frequency |
New PWM desired frequency in Hz | |
Return |
SetValue |
Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD) | |
Name |
Value |
Return |
SetDuty10Bit |
Set the Duty Cycle for this PWM Channel. PIC/AVR - Range: 0-1023 16-bit PIC - Range: 0-65535 | |
duty |
Duty value 0 - 1023 | |
Return |
SetDutyFloat |
Advanced function for the ESP32 hardware to set the PWM duty as a percentage between 0.0 and 100.0 | |
Duty |
Return |
GetList |
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property | |
Name |
Return |
