Component: Piezo Sounder (Audio Output)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Category Audio Output
Piezo Sounder component
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation. To actually drive a piezo you may have to amplify the signal from the microcontroller using a transistor or MOSFET.
Please click here for the component source code: FC_Comp_Source_PiezoSounder.fcfx
Here is a simple example that will create a siren effect using a piezo sounder. FC6 Icon.png Piezo Siren Depending on your Piezo Sounder you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
Fc9-comp-macro.png BuzzerBeep
Switches the buzzer on and off automatically to allow for a series of beeps
Fc9-u16-icon.png - UINT OnTime
Length of time in ms the buzzer will remain on
Fc9-u16-icon.png - UINT OffTime
Length of time in ms the buzzer will remain off
Fc9-u8-icon.png - BYTE NumberLoops
Number of times to repeat the sequence. Range 1-255
Fc9-u16-icon.png - UINT Frequency
frequency in hz to output to the Piezo sounder
Fc9-comp-macro.png BuzzerOnDelay
Switch the Buzzer on for a fixed amount of time
Fc9-u16-icon.png - UINT Time
Time in milliseconds to keep the buzzer on
Frequency to output in Hz
Fc9-type-5-icon.png Output Pin
Pin used to drive the output to the buzzer
