Author
Matrix Ltd.
Version
2.3
Category
Comms: Networking
WLAN ESP32 (Dummy) component
Wireless LAN component designed to work with ESP32 modules
Please click here for the component source code: FC_Comp_Source_WLAN_ESP32_Dummy.fcfx
Here is an example Flowcode program to send analogue data to a html web page.
The web page is set up to refresh every second
Instructions on how to change the refresh rate and access the web page is explained within the example file.
ESP Webpage
SocketConnect
- STRING
Address
- UINT
Port
- BYTE
SocketListen
Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail
- UINT
Port
- BYTE
ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE
Index
SSID Index
- STRING
CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING
SSID
Name of the wireless network to create
- STRING
Password
Password used to gain access to the network
- BYTE
802.11 Channel Range 1-14
- BYTE
Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE
ReadIP
Collects the local IP address
- BYTE
Index
- BYTE
SocketWrite
- STRING
Buffer
- UINT
Size
- UINT
ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE
Index
SSID Index
- INT
ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE
Index
SSID Index
- BYTE
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING
SSID
- STRING
Key
- BYTE
Timeout
Number of seconds to wait for the connection, default 20
- BYTE
SocketOpen
Returns 1 if socket sucessfully opened
- BYTE
SocketClose
AcceptOpen
Returns 1 if there is an incoming connection on the listening port
- BYTE
ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
- BYTE
SocketRead
- STRING
Buffer
- UINT
Size
- UINT
AcceptClose
Close the socket associated with the Accepted incoming connection
Initialise the WiFi system Returns 1 if successful Returns 0 if not
- BYTE
Simulation Method
Decides how to handle the simulation of the component. TCP Base - Allows simulation of the network communications using the TCP Base component and DLL. COM/Injector - Allows the simulation to connect to real hardware or injectors.
