Component: ADC Template 2D (Analog Input)
Author | Matrix Ltd |
Version | 1.3 |
Category | Analog Input |
ADC Template 2D component
Base ADC component with no graphical interface. Contains all of the embedded side component calls to provide an ADC interface suitable for wrapping with a new ADC style component.
Please click here for the component source code: FC_Comp_Source_adc_Base_2dgdi.fcfx
RawSampleInt |
Background call to read the ADC at full bit depth Call Enable() first | |
Return |
GetSampleBits |
Gets the number of bits per sample | |
Return |
GetString |
Reads the ADC as a direct voltage and returns as a string | |
Return |
GetAverageByte |
Function call to read the ADC as a byte average sample over time | |
NumSamples |
DelayUs |
Number of micro seconds in between taking each sample | |
Return |
RawAverageInt |
Background call to read the ADC as a full width average sample over time Call Enable() before this | |
NumSamples |
DelayUs |
Return |
GetSpeedFilter |
Gets the Conversion speed filter string Use in Component.Property.SetFilter() | |
Return |
GetAverageInt |
Function call to read the ADC as a full width average sample over time | |
NumSamples |
DelayUs |
Return |
GetVoltage |
Reads the ADC as a direct voltage | |
Return |
RawEnable |
Enables and configures the ADC channel to be an analogue input. Only one ADC channel can be enabled at a time. Any RAW functions will reference the last enabled channel only. | |
Return |
SetChannel |
Sets the channel ID for the component | |
ChannelId |
Chaannel starting at 0, -1 is unconnected | |
Return |
RawSampleByte |
Background call to read the ADC as a byte Call Enable() before this | |
Return |
GetInt |
Blocking call to read the ADC at full bit depth | |
Return |
RawDisable |
Disables the previously enabled ADC channel and converts back to digital mode. | |
Return |
GetByte |
Blocking call to read the ADC as a byte | |
Return |
