Component: Switch Array (Slide) (Switches)
Author | Matrix Ltd. |
Version | 2.0 |
Category | Switches |
Switch Array (Slide) component
An array of up to eight slide switches, each connected to a single pin of the specified port.
Please click here for the component source code: FC_Comp_Source_switch_array_slide.fcfx
Here is an example Flowcode program to read the values of a switch array.
Switch Array
(5V / 11K) * 10K = 4.54545V
ReadState |
Read the state of the switch at the given index. | |
Index |
The switch to read the status of. | |
Return |
WaitUntilHigh |
Pause the program until the switch at the given index is turned on. | |
Index |
Index of the switch to wait for. | |
Return |
ReadAll |
Reads all of the switches at once, returning a byte containing one bit per switch. | |
Return |
GetHandle |
Retrieves the object handle of the switch component at the given index. | |
Index |
Return |
WaitUntilLow |
Index |
Return |
