Component: DALI Slave (Comms: System)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Comms: System |
DALI Slave component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND using external circuitry.
Please click here for the component source code: FC_Comp_Source_DALI_Slave.fcfx
ReceiveForwardFrame |
Attempts to receive an 16-bit command from the master controller. 0xFFFF indicates timeout or no reply | |
Return |
CheckForIndividualAddress |
Tests the 16-bit incoming data for the defined individual address Returns 0 for no match, returns 1 for a match | |
Data |
Return |
CollectDataByte |
Returns the data byte from a 16-bit data packet | |
Data |
Return |
CheckForGroupAddress |
Tests the 16-bit incoming data for the defined group address Returns 0 for no match, returns 1 for a match | |
Data |
Return |
CollectPacketType |
Returns if the incoming packet was data or a command. Return of 0 = Data Return of 1 = Command | |
Data |
Return |
TransmitBackwardFrame |
Send out a 8-bit frame consisting of a data byte. | |
Data |
Data Byte | |
Return |
Initialise |
Configures the UART serial interface. | |
Return |
Properties |
Serial Properties |
TX Pin |
RX Pin |
DALI Slave Properties |
Individual Address |
Address ranging from 0-63 | |
Group Address |
Address ranging from 0-15 | |
Simulation |
API |
