Component: Digital Multimeter (HY3131) (Sensors)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Sensors
Digital Multimeter component
A component allowing access to the digital multimeter IC HY3131.
Please click here for the component source code: FC_Comp_Source_DMM_HY3131.fcfx
Fc9-comp-macro.png ReadRegister
A simple example showing a generic way to read a register using I2C.
Fc9-comp-macro.png WriteRegister
A simple example showing a generic way to write a register using I2C.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png SPI Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-7-icon.png Use Auto CS
Allow the SPI component to manage the CS pin for us in Master mode. On initialise the CS pin is automatically set high to disable the remote SPI device. Set to No if you want to create a component with multiple CS pins or if you want to manage the CS pin yourself.
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Options
Fc9-type-16-icon.png Mode
Configures the mode of the SPI component. Currently only Master mode is supported.
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-16-icon.png Clock Phase
Fc9-type-16-icon.png Clock Polarity
Fc9-type-16-icon.png Sample Point
Data bit read sample point
Fc9-conn-icon.png Simulation
Fc9-conn-icon.png Scale
Fc9-type-16-icon.png Select Scale
