| Author
Matrix Ltd
| Version
1.1
| Category
DSP Operators
Offset component
Allows the values in a single buffer to be offset uniformly. Functions include: Add, Subtract
Please click here for the component source code: FC_Comp_Source_DSP_Offset.fcfx
Calculate
| Performs the selected offset on a value from the input buffer and passes to the output buffer.
CalculateArray
| Performs the selected offset on an entire buffer.
SetOffset
| Sets the Offset to be used when calling the calculate function.
- INT
Offset
Connect To
| DSP component with output buffer to collect our data from.
Buffer Size
| Number of individual elements the buffer can store, default 1.
Buffer Type
| Sets the buffer data type.
Direction
| Sets the data direction flow of the component
Offset
Offset Type
| Defines the type of calculation performed on the input buffer to obtain the output value. A left shift is essentially an optimised multiply with the multiplier being the 2^scaler A right shift is essentially an optimised divide with the divider being the 2^scaler
Rollover
| Allow the output buffer to rollover. For example 128 + 128 = 256 which would equate to 0 using an 8-bit buffer with rollover enabled. With rollover disabled the output would be set to 255 which is the max representable value.
Initial Offset
