Author
Matrix Ltd.
Version
2.1
Category
E-blocks 2
WIFI component
Wireless LAN component designed to work with the ESP-12S module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the BL0136 WIFI E-block.
Please click here for the component source code: FC_Comp_Source_EBlocks2_WLAN_ESP12S_BL0136.fcfx
The examples below are all done using a EB091 board as the host
The EB069 ESP8266 Wifi E-block is connected to PORTD 0-7 with the patch setting set to B.
The EB005 LCD E-block is connected to PORTB 0-7 with the patch setting set to Default.
Other host boards are compatible with the examples, simply change the target chip and component connection properties.
Firmware Test
This example collects the firmware version from the ESP8266 module and displays it on an LCD. Tested working with firmware version 00150900.
FirmwareTest
Wireless Scanner
This example scans for wireless networks in range and prints the network IDs to the LCD along with the signal strength and security type.
WifiScan
Creating An Access Point
This example creates an access point you can connect your phone or laptop to named Flowcode_ESP8266. The password to connect to the access point is flowcode6.
Note this example simply creates an access point, no data is transferred.
CreateAP
Joining An Access Point
This example joins an existing access point. The network ID and Password must be altered to match your local WIFI network settings.
Note this example simply joins an access point, no data is transferred.
JoinAP
TCP Client
Once joined to the network the example connects to the MatrixTSL website and requests a file which is printed out on the LCD.
TCPClient
TCP Server
Once the access point is created the example shows the server IP address on the LCD.
Connecting to the wireless network on your phone or laptop and visiting the IP address shown on the LCD using a web browser allows you to switch LED outputs on and off.
TCPServer
Network Comms
Here are some examples using the Network Communication component linked to the ESP8266 component.
NetworkComms ESP8266 Client
NetworkComms ESP8266 Webserver
SendString
Sends the given Text with no preappendment. Useful for sending preformatted command strings. Appends a CR to the end of the string if SendCR is greater than 0.
- STRING
Text
- BYTE
SendCR
DisconnectFromSSID
Disconnects from the current SSID. Returns 1 if the command was accepted and returned an "OK"
- BYTE
ClientConnect
Creates a TCP or UDP connection to a remote server. Returns the state of the connection. 0=Connection failed 1=Connection active
- BYTE
Type
0 = TCP, 1 = UDP
- STRING
IPAddress
e.g. "192.168.1.20"
- UINT
Port
Remote port number to connect to, HTTP comms = Port 80
- BYTE
ControlTCPServer
Allows a TCP web page server to be switched on and off on the selected port. Returns 1 if the command was completed correctly.
- BYTE
Enable
0 = Stop Server, 1 = Start Server
- UINT
Port
Server port to listen for incoming TCP/IP data requests
- BYTE
GetFirmwareVersion
Collects the firmware version from the ESP8266 module and returns it as a string.
- STRING
CheckForPageRequests
- BYTE
ClientSendRequest
Sends out a string with the required AT+CIPSEND=Length$(Request) initialiser.
- STRING
Request
e.g. "GET / HTTP/1.0\r\n\r\n"
ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE
Index
SSID Index
- STRING
CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING
SSID
Name of the wireless network to create
- STRING
Password
Password used to gain access to the network
- BYTE
802.11 Channel Range 1-14
- BYTE
Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE
SetOutValue
- BYTE
index
Range 0-4
- STRING
value
EndServerConnection
Disconnects from the current active TCP/IP pipe.
- BYTE
Send_Embedded_HTML_Page4
ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE
Index
SSID Index
- BYTE
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page1
ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE
Index
SSID Index
- BYTE
GetByteWithTimeout
Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available.
- BYTE
GetInValue
- BYTE
index
Index of the request paramter, starting at zero Range 0-2
- STRING
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING
SSID
- STRING
Key
- BYTE
Timeout
Number of seconds to wait for the connection, default 20
- BYTE
ClientSendArray
Sends out an array of data bytes with the required AT+CIPSEND=Length$(Request) initialiser.
- BYTE
Data
- UINT
NumBytes
GetRxArray
Attempts to receive a number of bytes from the remote connection If nothing is available then waits up to 200 ms for data to become available. Returns the number of bytes received,.
- BYTE
Data
Byte array to store the incoming data
- UINT
MaxBytes
Maximum number of bytes to try and receive
- UINT
ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
- BYTE
Initialise the device with the property data. Returns 1 if "ready" message successfully received Returns 0 if no reply from module
- BYTE
CheckTCPServerIP
Collects the local IP address of the active TCP server.
- STRING
WIFI Properties
Receive Buffer Size
Buffer used to store incoming data ready for processing. Default 128 Bytes.
Scan Buffer Size
Buffer used to hold SSID names when performing a SSID network scan. Default 100 Bytes.
Reset Mode
The initialise automatically resets the WIFI module before establishing communications. Software reset uses an AT command to preform the reset Hardware reset uses an extra I/O pin to toggle the signal to the reset pin on the module.
Command Termination
Older versions of the firmware require \r to terminate a AT command string. Newer versions of the firmware have changed to use \r\n termination.
Baud Options
TX
RX
Reset
WLAN module reset pin connection
Use Flow Control
HTML Source
Max Web Pages
Maximum number of individual webpages we can serve up with the component.
Web Page Timeout
Number of cycles to try and send / receive a webpage before timing out.
Line Delay
Fixed delay in microseconds sent in between sending a HTML line when running as a web page server.
Name Page 1
HTML name of webpage 1
HTML Page 1
HTML content for webpage 1
Name Page 2
HTML name of webpage 2
HTML Page 2
HTML content for webpage 2
Name Page 3
HTML name of webpage 3
HTML Page 3
HTML content for webpage 3
Name Page 4
HTML name of webpage 4
HTML Page 4
HTML content for webpage 4
Substitutions
Outgoing
Count
Length 0
Incoming
Count
Length 0
Show Comms Flasher
Simulation Method
Decides how to handle the simulation of the component. TCP Base - Allows simulation of the network communications using the TCP Base component and DLL. COM/Injector - Allows the simulation to connect to real hardware or injectors.
Console Columns
Data Source
