Component: DC Motor (Half Bridge) ()
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.1
Category
DC Motor (Half Bridge) component
DC Motor that can be driven in a single direction using digital output pin.
Please click here for the component source code: FC_Comp_Source_Motor_simple.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels. FC6 Icon.png Motors
Fc9-comp-macro.png Stop
Turn off power to the motor by turning off its pin.
Fc9-comp-macro.png Start
Set the motor running by turning on its pin.
Fc9-type-5-icon.png Pin
Fc9-type-16-icon.png Active State
Fc9-conn-icon.png Motor Settings
Fc9-type-16-icon.png Direction
Fc9-type-15-icon.png Speed
Speed of the motor when turned on.
Fc9-type-15-icon.png Acceleration
Speed change per second when the motor us powered. Set to zero for instantaneous speed changes.
Fc9-type-15-icon.png Deceleration
Speed change per second when the motor is coasting with no power. Set to zero for instantaneous speed changes.
Fc9-type-7-icon.png Show Actuator
When activated, an actuator will appear so that the animation can be seen more easily.
Fc9-conn-icon.png Linkage
Fc9-type-17-icon.png Target Object
An object or group to link the motor to - the object will move along with the motor.
