Component: DC Motor ()
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 1.2 |
Category |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here for the component source code: FC_Comp_Source_Motor_with_reverse.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels.
Motors
Coast |
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
Return |
Break |
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
Return |
Disable |
Disable the motor output | |
Return |
Forwards |
Set the motor turning in the forwards direction by setting the pins according to the 'Reverse Pattern' property. | |
Duty |
Sets the motor power for PWM or H-Bridge outputs | |
Return |
Enable |
Enables the motor output | |
Return |
Reverse |
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
Duty |
Return |
