Component: SCADA (Dummy) (SCADA Slaves)
Version | 1.0 |
Category | SCADA Slaves |
SCADA (Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_OLD_API_Slave_Dummy.fcfx
I2CInitialise |
Initialsie the I2C module ready for communications | |
Return |
IOGetInputPin |
Sets the selected digital pin to an input and reads the input state. | |
Pin |
Range: 0-13 | |
Return |
I2CRestart |
Put the I2C Module into Restart mode | |
Return |
I2CStart |
Put the I2C Module into Start mode | |
Return |
SPITransfer |
Transfer a byte using the SPI bus | |
DataOut |
Return |
I2CReceive |
Receive a byte using the I2C bus | |
Last |
Last byte to receive: Range 0-1 | |
Return |
I2CStop |
Put the I2C Module into Stop mode | |
Return |
SPIPrescaler |
Modify the speed of the SPI bus | |
Prescaler |
Range: 0-2 | |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-13 | |
State |
Range: 0-1 | |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
DataOut |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
Properties |
