Component: SPI Master (EB013) (E-blocks 1)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category E-blocks 1
SPI Master component
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in. If the hardware SPI pins are in use or more SPI channels are required then there is also a software mode available. Has additional functions to work with the E-blocks EB013 SPI hardware.
Please click here for the component source code: FC_Comp_Source_SPI_Legacy.fcfx
Fc9-comp-macro.png SendString
Sends a string of bytes to the SPI bus
Fc9-comp-macro.png NVMSendChar
Send a byte to the non-volatile memory device on the EB013 SPI E-block.
Fc9-u32-icon.png - ULONG Address
NVM Address to write data to
Fc9-u8-icon.png - BYTE Data
Data Byte to write to the sepected memory location
Fc9-comp-macro.png GetString
Attempts to read a string of bytes from the SPI bus.
Fc9-u8-icon.png - BYTE NumBytes
Fc9-u8-icon.png - BYTE Ch
Fc9-comp-macro.png DACSendChar
Send a byte to the digital to analogue converter (DAC) on the EB013 SPI E-block.
Data byte to output using the DAC
Fc9-comp-macro.png SendChar
General purpose SPI send byte macro
Fc9-u8-icon.png - BYTE Char
Fc9-comp-macro.png NVMGetChar
Reads a byte from the non-volatile memory device on the EB013 SPI E-block.
NVM Address to read data from
Fc9-comp-macro.png EnableFram
Enable the SPI RAM chip on the EB013 SPI E-block.
Fc9-comp-macro.png FramOutput
Send a value to the RAM on the EB013 SPI E-block.
Fc9-comp-macro.png DisableFram
Disable the SPI RAM chip on the EB013 SPI E-block.
Fc9-comp-macro.png GetChar
General purpose SPI get byte macro
Fc9-comp-macro.png UnInitialise
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O.
Fc9-comp-macro.png Initialise
Activates the SPI peripheral and claims control over the I/O pins.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png DAC En
DAC enable pin - only used with the EB013 SPI E-block
Fc9-type-5-icon.png NVM En
NVM enable pin - only used with the EB013 SPI E-block
Fc9-conn-icon.png Bus Settings
Fc9-type-16-icon.png Board Version
The Latest version of the E-block have a newer NVM IC which requires 3 address bytes instead of 2 address bytes. If you find that the NVM is not responding to commands then try changing the version property to match the version of the E-block. The version is written on the board as EB013-00-X where X is the version number.
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-16-icon.png Clock Phase
Fc9-type-16-icon.png Clock Polarity
Fc9-type-16-icon.png Sample Point
Data bit read sample point
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Label used to identify the component on the panel.
Fc9-type-16-icon.png API
