Component: SPI Slave (Comms: Interface)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Category Comms: Interface
SPI Slave component
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in.
Please click here for the component source code: FC_Comp_Source_SPI_Slave.fcfx
Simple Master program that sends an incrementing test value to the SPI bus as well as outputting the value onto LEDs.
FC6 Icon.png SPI_Master
Simple Slave program that collects the value sent by the master and outputs the value onto LEDs. Allows the master slave comms to be compared to check that everything is working correctly.
FC6 Icon.png SPI_Slave
Another simple example to buffer incoming SPI bytes sent by the master and output these to the LCD.
FC6 Icon.png SPI_Slave2
Fc9-comp-macro.png SendChar
General purpose SPI send byte macro
Fc9-u8-icon.png - BYTE Char
Data byte to send
Fc9-comp-macro.png GetChar
General purpose SPI get byte macro
Fc9-comp-macro.png UnInitialise
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O.
Fc9-comp-macro.png Initialise
Activates the SPI peripheral and claims control over the I/O pins.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-7-icon.png Use Slave Select
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Bus Settings
Fc9-type-16-icon.png Clock Phase
Fc9-type-16-icon.png Clock Polarity
Fc9-type-16-icon.png Sample Point
Data bit read sample point
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Label used to identify the component on the panel.
Fc9-type-16-icon.png API
