Component: Thermocouple (MAX31855) (Environmental)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Category Environmental
Thermocouple (MAX31855) component
Component to interface the MAX31855 IC from MAXIM. Uses a standard 3-wire SPI interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Please click here for the component source code: FC_Comp_Source_ThermocoupleMAX31855.fcfx
Example program showing how to use the Thermocouple component. FC6 Icon.png MAX31855_Example
Fc9-comp-macro.png ReadReference_Int
Returns the reference temperature from the last sample as an integer value in Degrees C.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png ReadReference_Float
Returns the reference temperature from the last sample as a floating point value in Degrees C.
Fc9-comp-macro.png Sample
Reads the memory of the MAX31855 IC and checks for errors. Must be called before any of the Read functions. Returns: 0=OK, 1=Open Circuit, 2=Short GND, 3=Short VCC
Fc9-comp-macro.png ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value in Degrees C.
Fc9-comp-macro.png ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value in Degrees C.
Fc9-comp-macro.png Initialise
Configures the SPI bus ready for communications.
Fc9-conn-icon.png Thermocouple Properties
Fc9-type-16-icon.png Thermocouple Type
Specified at the end of the MAX part number MAX31855X where X is the Thermocouple type. Selects which type of thermocouple the IC works with.
Fc9-conn-icon.png SPI Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Simulation
