Component: Thermocouple (MCP960X) (Environmental)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Environmental
Thermocouple (MCP960X) component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Please click here for the component source code: FC_Comp_Source_ThermocoupleMCP960X.fcfx
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
FC6 Icon.png MCP960X Demo
Sim Demo
Fc9-comp-macro.png ReadReference_Int
Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png ReadRawDataADC
Returns the thermocouple temperature from the last sample as an integer value in Degrees C.
Fc9-comp-macro.png ReadReference_Float
Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures.
Fc9-comp-macro.png Sample
Must be called before any of the Read functions. Reads the memory of the MCP9600/1 IC. Returns 0 for 9600. Checks for errors, MCP9601 only. Returns: 0 = OK, 1 = O/ C Themocouple & 2=S/C Themocouple.
Fc9-comp-macro.png ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures.
Fc9-comp-macro.png ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value. Use Sample first, which samples both reference & themocouple temperatures.
Fc9-comp-macro.png Initialise
Configures the I2C bus ready for communications.
Fc9-conn-icon.png Thermocouple Properties
Fc9-type-16-icon.png Thermocouple Type
Thermocouple type. Selects which type of thermocouple the IC works with.
Fc9-type-16-icon.png Filter Coefficients
Digitial filter selection. The higher the number the better the filter. Results more stable but take longer to update.
Fc9-type-16-icon.png Unit
Select Temperature results to be celsius or fahrenheit
Fc9-conn-icon.png I2C Properties
Fc9-type-21-icon.png Address
Address ranges 0x60 - 0x67 (96 - 103)
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
