Component: PIC32 Core Timer (Timing)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Timing |
PIC32 Core Timer component
Allows for easy and accurate timings using the built in Core timer on the PIC32 devices.
Please click here for the component source code: FC_Comp_Source_TimerComponentPIC32Core.fcfx
Start_S |
A none blocking function that allows for accurate delays to be specified in seconds using the core timer. | |
Delay |
Return |
Start_InstructionCount |
A none blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer. | |
Delay |
Return |
Delay_S |
A blocking function that allows for accurate delays to be specified in seconds using the core timer. | |
Delay |
Return |
Start_Ms |
A none blocking function that allows for accurate delays to be specified in milliseconds using the core timer. | |
Delay |
Return |
Start_Us |
A none blocking function that allows for accurate delays to be specified in micro seconds using the core timer. | |
Delay |
Return |
Delay_Ms |
A blocking function that allows for accurate delays to be specified in milliseconds using the core timer. | |
Delay |
Return |
Delay_InstructionCount |
A blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer. | |
Delay |
Return |
Start_Ns |
A none blocking function that allows for accurate delays to be specified in nano seconds using the core timer. | |
Delay |
Return |
Delay_Us |
A blocking function that allows for accurate delays to be specified in micro seconds using the core timer. | |
Delay |
Return |
Delay_Ns |
A blocking function that allows for accurate delays to be specified in nano seconds using the core timer. | |
Delay |
Return |
Check_Counter |
Checks to see if the counter time is elapsed. Used in conjunction with the Start_ component macros. Returns 1 if complete or 0 if still counting. | |
Return |
Properties |
