Component: Potentiometer (Black) ()
Revision as of 14:14, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category
Potentiometer (Black) component
Potentiometer with black plastic knob. Pointer colour can be changed in component properties.
Please click here for the component source code: FC_Comp_Source_pot_Black.fcfx
Potentiometer Example
Start Angle
Sweep Angle
Color
Colour of the pointer.
Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
