Component: Switch (Push, Panel) ()
Revision as of 14:14, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Switch (Push, Panel) component
Large round push switch with chrome bezel for panel mounting.
Please click here for the component source code: FC_Comp_Source_sw_push_rnd_pnl.fcfx
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
Error creating thumbnail: Unable to save thumbnail to destination
(5V / 11K) * 10K = 4.54545V
Connection
Chip pin to which this switch is connected.
Polarity
Sets whether activating the switch sets the chip pin high or low.
Debounce (ms)
Time in milliseconds allowed for the switch to stabilise after a change of state. NB) This applies only when using the component macros to read the button state- chip pin is not debounced.
Operation
Latching - click the button to turn the switch on, click again to turn it off. Momentary - click the button to turn it on, release the mouse to turn it off.
