Component: API I2C Dummy (API Slave Devices)
Revision as of 15:12, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API I2C Dummy component
API I2C Dummy
Please click here to view the component source code (Beta): FC_Comp_Source_API_I2C_Dummy.fcfx
Fc9-comp-macro.png I2CInitialise
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
Fc9-comp-macro.png I2CTransReceive
Fc9-u8-icon.png - BYTE Data
Data variable to receive into
Fc9-u16-icon.png - UINT Count
Number of bytes to receive
Fc9-comp-macro.png I2CRestart
Fc9-comp-macro.png I2CStart
Fc9-comp-macro.png I2CReceive
Fc9-bool-icon.png - BOOL Last
Fc9-comp-macro.png I2CStop
Fc9-comp-macro.png I2CTransSend
Data to send
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
Fc9-comp-macro.png I2CSend
Fc9-comp-macro.png Initialise
Data to send
