Component: BBC Weather Forecast (Comms: IoT/Cloud)
Revision as of 15:13, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: IoT/Cloud
BBC Weather Forecast component
Easily allows you to collect three day forecasted weather metrics for your area using the BBC Weather data service. Supports Min/Max temperature, Wind Direction, Wind Speed, Visibility, Pressure, Humidty, UV Risk, Pollution and Sun Rise/Set times for your selected area.
Please click here to view the component source code (Beta): FC_Comp_Source_BBCWeatherForecast.fcfx
Here is a basic example to read the three day forecast data and report the information on a graphical display.
FC6 Icon.png BBCWeatherForecastDemo
The location can be set by adjusting the BBC Weather location property, see the component property tooltips for more information on how to do this.
On an embedded device you would need a TCP/IP component to allow the communications to the BBC server. This then links to the Network Comms component.
Fc9-comp-macro.png GetMaxTemperature
Reads the forecast maximum temperature in the selected scale for the selected day.
Fc9-bool-icon.png - BOOL Scale
0 = Celcius, 1 = Farenheit
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png GetVisibility
Reads the forecast visibility for the selected day.
Fc9-comp-macro.png GetDaySummary
Gets the summary of the currently selected day as a string.
Fc9-comp-macro.png GetMinTemperature
Reads the forecast minimum temperature in the selected scale for the selected day.
Fc9-comp-macro.png GetWindDirection
Reads the forecast wind direction as a string for the selected day.
Fc9-comp-macro.png RequestData
Requests data about your selected location from the BBC weather service. Returns true if the request was successful. Must be called before trying to call any of the GetXXX macros.
Fc9-comp-macro.png GetPollution
Reads the forecast pollution as a string for the selected day.
Fc9-comp-macro.png GetSunset
Reads the forecast sunset time as a string for the selected day.
Fc9-comp-macro.png GetHumidity
Reads the forecast humidity in Relative Humdity for the selected day.
Fc9-comp-macro.png GetDayName
Gets the name of the currently selected day as a string.
Fc9-comp-macro.png GetWindSpeed
Reads the reported wind speed in MPH for the selected day.
Fc9-comp-macro.png SetLocationCode
Allows the location code to be altered from the default location code set in the component properties. After changing the location the RequestData macro must be called to refresh the forecast variables.
Fc9-string-icon.png - STRING NewLocation
New location string, see Location property tooltip for more info.
Fc9-comp-macro.png GetSunrise
Reads the forecast sunrise time as a string for the selected day.
Fc9-comp-macro.png GetPressure
Reads the forecast air pressure in milli bar (mb) for the selected day.
Fc9-comp-macro.png SetForecastDay
Chooses which day of the three day forecast to look at.
Fc9-u8-icon.png - BYTE Day
0 = Today, 1 = Tomorrow, 2 = Day After Tomorrow
Fc9-comp-macro.png GetUVRisk
Reads the forecast UV Risk for the selected day.
Fc9-comp-macro.png GetLocationName
Reads the reported location name as a string.
Fc9-comp-macro.png Initialise
Sets up the component ready to collect weather data.
Fc9-type-16-icon.png LinkTo
Fc9-type-10-icon.png BBC IP Address
IP Address linked to the following URL: weather-broker-cdn.api.bbci.co.uk
Fc9-type-10-icon.png Location Code
BBC code for your area. In a web browser go to www.bbc.co.uk/weather/ Then type in your city in the search bar and your code will be shown at the end of the URL. For example Manchester in the UK = 2643123 In the UK you can also use the first half of your post code, e.g. HX1
Fc9-type-21-icon.png Receive Timeout
Maximum time to wait for valid incoming data.
