Component: Level (DSP Outputs)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Outputs |
Level component
Allows for detection and collection of peaks, troughs and averages.
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Level.fcfx
Here is a basic example of the Level component. The example collects the max, min and average readings from the buffer and displays them on the LCD display.
The values in the buffer are defined using the InputADC component.
Min: Minimum (smallest) value read from the buffer.
Max: Maximum (largest) value read from the buffer.
Average: Rolling average calculated from the values inside the buffer.
| ReadTroughArray | |
| Returns the lowest value from the last "Decay" number of buffers. | |
| ReadTrough | |
| Returns the lowest value from the last "Decay" number of index locations. | |
| ReadAverage | |
| Returns the average from the last "Decay" number of index locations. | |
| ReadPeakArray | |
| Returns the highest value from the last "Decay" number of buffers. | |
| ReadAverageArray | |
| Returns the average from the last "Decay" number of buffers. | |
| ReadPeak | |
| Returns the highest value from the last "Decay" number of index locations. | |
| ResetRecords | |
| Allows the peak and trough to be reset back to default values. | |
| ResetPeak | |
| ResetTrough | |
| ReadTroughArray | |
| ReadTrough | |
| ReadAverage | |
| ReadPeakArray | |
| ReadPeak | |
| ResetRecords | |
| ResetPeak | |
| ResetTrough | |
