Component: Multiplex (DSP Operators)
Revision as of 15:13, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Multiplex component
Allows multiple input buffers to be multiplexed to a single output buffer.
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Mpx.fcfx
Multiplex
Passes a single value from the selected input buffer into the output buffer.
SetMultiplexSource
Specifies the source buffer to copy through to the output buffer.
- BYTE Source
- BOOL ResetInputIndex
0=Leave Index, 1=Reset Index to 0
MultiplexArray
Passes an entire buffer through the multiplexer.
Connect To 0
Connect To 1
Buffer Size
Buffer Type
Sets the buffer data type.
Multiplex
Number of Inputs
The number of inputs the multiplexer can switch between.
Multiplex
SetMultiplexSource
- BYTE Source
MultiplexArray
Connect To 0
Connect To 1
Buffer Size
Buffer Type
Multiplex
Number of Inputs
