| Author
Matrix Ltd
| Version
1.2
| Category
DSP Outputs
Output Digital Pin component
Allows the values from a buffer to be passed directly to a digital output pin based on a defined threshold.
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_OutputPin.fcfx
SetPin
| Takes the value from the connected DSP buffer and outputs to the selected pin based on the selected threshold values.
Connect To
| DSP component with output buffer to collect our data from.
Output Pin
Threshold Value
| Sets the level at which the pin goes into the active state. >= the threshold the pin will be in the active state. < the threshold the pin will be in the none active state.
Pin State
| Selects the output level to use when the pin is in the active state. Active High - Pin will pull to VCC (high) when active and pull to VSS (low) when none active. Active Low - Pin will pull to VSS (low) when active and pull to VCC (high) when none active.
SetPin
Connect To
Output Pin
Threshold Value
Pin State
