Component: Scale (DSP Operators)
Author | Matrix Ltd |
Version | 1.1 |
Category | DSP Operators |
Scale component
Allows the values in a single buffer to be scaled uniformly. Functions include: Multiply, Divide, LeftShift, RightShift, Float Multiply, Float Divide
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Scale.fcfx
Here is an example which demonstrates variable scaling based on an analogue input.
Here are the traces as seen on the data recorder window.
The RightShift macro is a very efficient means of performing a division but only for values which are a power of 2.
The LeftShift macro is a very efficient means of performing a multiplication but only for values which are a power of 2.
LeftShift(1) = Multiply by 2 / RightShift(1) = Divide by 2
LeftShift(2) = Multiply by 4 / RightShift(2) = Divide by 4
LeftShift(3) = Multiply by 8 / RightShift(3) = Divide by 8
LeftShift(4) = Multiply by 16 / RightShift(4) = Divide by 16
SetScalerFloat |
Sets the Float scaler to be used when calling the calculate function. | |
Scaler |
Return |
SetScalerInteger |
Sets the Integer scaler to be used when calling the calculate function. | |
Scaler |
Return |
Calculate |
Performs the selected scaling on a value from the input buffer and passes to the output buffer. | |
Return |
CalculateArray |
Performs the selected scaling on an entire buffer. | |
Return |
SetScalerFloat |
Scaler |
Return |
SetScalerInteger |
Scaler |
Return |
Calculate |
Return |
CalculateArray |
Return |
