| Author
Matrix TSL
| Version
1.0
| Category
Runtime Tools
Timed Event Trigger component
Component that will check to see if a predetermined amount of time has passed. Useful for doing things on a regular basis, e.g. every minute or every hour.
Please click here to view the component source code (Beta): FC_Comp_Source_EventTrigger.fcfx
Reset
| Resets the countdown timer
SetTimePeriod
| Sets the time period in seconds. Ideally this should only be called when the timer is not running. Automatically stops, resets and restarts the timer if already running.
- ULONG
Time
| Time period in units specified
- BYTE
Units
| 0=Seconds, 1=Minutes, 2=Hours
Stop
| Stops the countdown timer running
CheckTrigger
| Checks the state of the trigger to determine if the allocated amount of time has passed. Returns true if amount of time has passed, otherwise returns false.
- BOOL
Start
| Starts the countdown timer running. Automatically performs a reset if the event has already been triggered.
Time Period Units
| Units of time to wait for
Time Period Value
| Number of time periods to wait before firing
Call a macro
| Decides if a user macro wil be called when the event time period is over. No - requires the use of polling in your application by calling the CheckTrigger component macro. Yes - Automatically calls the selected user macro
Auto Reset
| Yes: Automatically resets and restarts the timer when running and actioned. No: Waits for the user to restart the timer running by calling the Start macro.
Reset
SetTimePeriod
- ULONG
Time
- BYTE
Units
Stop
CheckTrigger
- BOOL
Start
Time Period Units
Time Period Value
Call a macro
Auto Reset
