Component: GLCD (KS0108) (Graphical Monochrome)
Revision as of 15:14, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category Graphical Monochrome
GLCD (KS0108) component
Graphical display component designed to work with the KS0108 type monochrome displays. Also compatible with the newer S6A0107 controller IC displays.
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_KS0108.fcfx
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Pixel_Colour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-type-16-icon.png Controller Count
Speicifies the number of controller IC's built into the display and therefore the number of available chip select pins
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-5-icon.png CS1
Chip select to address the first controller IC
Fc9-type-5-icon.png CS2
Chip select to address the second controller IC
Fc9-type-5-icon.png RS
Data / Instruction register select pin.
Fc9-type-5-icon.png RW
Read / write select pin
Fc9-type-5-icon.png Enable
Data enable to clock a command or data in or out of the device
Fc9-type-5-icon.png Data0
Data Pin 0
Fc9-type-5-icon.png Data1
Data Pin 1
Fc9-type-5-icon.png Data2
Data Pin 2
Fc9-type-5-icon.png Data3
Data Pin 3
Fc9-type-5-icon.png Data4
Data Pin 4
Fc9-type-5-icon.png Data5
Data Pin 5
Fc9-type-5-icon.png Data6
Data Pin 6
Fc9-type-5-icon.png Data7
Data Pin 7
Fc9-type-5-icon.png Reset
Display reset pin
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
Fc9-conn-icon.png Display Delay
Fc9-type-21-icon.png Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
0=White, 1=Black
0=White, 1=Black
Data Pin 0
Data Pin 1
Data Pin 2
Data Pin 3
Data Pin 4
Data Pin 5
Data Pin 6
Data Pin 7
Display reset pin
