Author
Matrix Ltd
Version
1.9
Category
Graphical Monochrome
GLCD (SSD1327) SPI component
Graphical display component based on the SPI version of the SSD1327 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1327_SPI.fcfx
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SendCommand
- BYTE
Command
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
ControlDisplay
Allows the display to be switched on and off
- BYTE
Control
0=Off, 1=On
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
Refresh
Refreshes the entire display by sending the contents of the local RAM to the display at high speed
SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE
Shade
ClearDisplay
SetBackgroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
Dimensions
Pixel Width
Pixel Height
Flip
Determines if the display is flipped or not
Auto Draw
Yes: Default - Lines, Text, Clear will all be done automatically No: Data will be sent only to the internal RAM, the display will be updated using the Refresh command
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
DC Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
Simulate Comms
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Communications
API
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SendCommand
- BYTE
Command
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
ControlDisplay
- BYTE
Control
0=Off, 1=On
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
- BYTE
Font
- BYTE
Index
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
Refresh
SetShadeIntensity
- BYTE
Shade
ClearDisplay
SetBackgroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
Dimensions
Pixel Width
Pixel Height
Flip
Auto Draw
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Prescale
MOSI
MISO
CLK
CS / SS
DC Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Simulate Comms
Communications
API
