API Panel.Position.Set
Revision as of 15:56, 15 May 2013 by (username removed) (→‎Flowcode example file)
<sidebar>API contents</sidebar> Sets an objects position based on a component or pre-defined position
Class hierarchy
Panel
Position
Set
HANDLE Dest
HANDLE Source
The position or component to read from
  • Add to a calculation icon:
    ::Panel.Position.Set(dest, source)
From the SimulationAPIExamples folder load SIMAPI_Panel_Position_Set.fcf file into Flowcode. In this example, there are two spheres. The red sphere has dimensions of 24h,24w,24d, the yellow sphere has dimensions of 12h,12w,12d. This is an important consideration when using the Set() function because it effectively clones the dimensions and coordinates of the source component.
What you will see in this demo is the red sphere move to the coordinates of the yellow sphere and also the red sphere will be resized to that of the yellow sphere. As there are now two objects of exact same dimensions and coordinates the red sphere may look like its dissapeared or you may see both spheres exhibiting some colour collision. The LCD will show the coordinates of both spheres.
After two seconds the red sphere will re-appear back in it's original location and to it's original size. Just using the set() function alone would have successfully moved it back to it's original coordinates but it would not have resized the red sphere back to it's original dimensions.
At the risk of going off topic here (slightly beyond the scope of this example), a clever technique can be used by creating a variable of type Handle then using the get() api call we pass a copy of the red spheres original size and coordinates to this variable. You can then use set() api call again this time specifying the variable as the source handle. You can see this clearly in the flowcode example.
The screenshots below show the effect and also highlight the code used by the example.
SIMAPI Panel Position Set Pic1.pngSIMAPI Panel Position Set Pic2.png SIMAPI Panel Position Set Pic0.png
