| Author
Matrix Ltd
| Version
1.0
| Category
Scenarios
Maze Generator component
Creates a simulation only randomised maze out of standard micromouse maze walls and pillars. Compatible with the Formula Flowcode robot.
Please click here to view the component source code (Beta): FC_Comp_Source_MazeGenerator.fcfx
GenerateMaze
| Clears the current maze and generates a new maze over the top. Automatically called when the size of the maze is altered.
Generation Settings
Maze Generation
| Specifies how the maze is generated. Manual - All walls are shown, clicking on a wall will remove it while the switch remains active. Random - A random maze is generated
Contained
| Decides if the maze is contained or if there are openings to allow the robot to escape the maze for obstacle course type simulations. No - Creates two holes in the side walls of the maze to match the longest path possible through the maze Yes - The maze is self contained
Dimensions
Width (Walls)
| The number of micromouse walls wide the maze should be
Length (Walls)
| The number of micromouse walls long the maze should be
Cell Count
| The total number of individual cells the maze will have
GenerateMaze
Generation Settings
Maze Generation
Contained
Dimensions
Width (Walls)
Length (Walls)
Cell Count
