Component: Network Communications (Comms: Networking)
Version | 1.5 |
Category | Comms: Networking |
Network Communications component
A component designed to simplify the process of TCP/IP communications. Compatible with most of the Flowcode supported TCP/IP and WIFI components. A useful building block for creating components such as IoT and Modbus TCP.
Please click here to view the component source code (Beta): FC_Comp_Source_NetworkComms.fcfx
Listen |
Bind the socket to a port on the local host and set to listen mode. First Open a Socket on the local host Returns: 0=Fail, 1=OK | |
Port |
Port number to listen on. | |
Return |
SocketOpen |
Attempts to create a socket on the local device. This must be succesful to allow TCP/IP communications with a remote destination. Returns: 0=Fail / 1=OK | |
Return |
SocketClose |
Closes the current socket connection | |
Return |
AcceptOpen |
Required for systems where there can be multiple incoming threads Returns 1 if there is incoming comms requiring a new thread, else returns 0 | |
Return |
AcceptClose |
Goes with the AcceptOpen function to close the new thread handle. | |
Return |
Initialise |
Initialises the network communications component. | |
Return |
Listen |
Port |
Return |
SocketOpen |
Return |
SocketClose |
Return |
AcceptOpen |
Return |
AcceptClose |
Return |
Initialise |
Return |
