Component: Network Communications Dummy (Comms: Networking)
Author | Matrix TSL |
Version | 1.1 |
Category | Comms: Networking |
Network Communications Dummy component
A component designed to simplify the process of TCP/IP communications. Compatible with most of the Flowcode supported TCP/IP and WIFI components. A useful building block for creating components such as IoT and Modbus TCP.
Please click here to view the component source code (Beta): FC_Comp_Source_NetworkCommsDummy.fcfx
Here are some examples showing the Network Communications component in action.
By itself the component provides a generic TCP/IP layer to drive the simulation runtime.
Here is a simple example showing the component used by itself to request data from a remote server on the internet.
Library Components
Components such as Webserver (GENERIC), MQTT and Modbus TCP can connect to and control the network comms layer.
Here is a simple example showing the component used with the Webserver (GENERIC) component.
Example Network Comms Web Server
Embedded Components
The Network Communications component can also be connected to embedded TCP/IP and WIFI style modules allowing for the abstraction to work with specific networking hardware modules.
Here is the current status of the Network Communications component with the various embedded modules.
Embedded Component | Other Variants of Component | Support Status |
TCP/IP (Raspberry Pi) | N/A | Fully Supported |
WLAN (ESP8266) | WLAN (ESP-12S), WIFI (BL0136), WIFI (ESP8266) | Fully Supported |
TCP/IP (W5500) | N/A | Fully Supported |
ENC28J60 | N/A | On Hold |
TCP/IP (NM7010A) | TCP/IP (EB023v1) | On Hold |
TCP/IP (W5100) | TCP/IP (EB023v2), TCP/IP (WIZ810MJ) | On Hold |
WLAN (WIZ610WI) | WIFI (EB069) | On Hold |
We are working through and adding support as and when we get chance so if you have a module that isn't listed or would like to try and prioritise a specific module then you can let us know via the user forums.
Listen |
Bind the socket to a port on the local host and set to listen mode. Returns: 0=Fail, 1=OK | |
Port |
Return |
SocketOpen |
Attempts to create a socket on the local device. This must be succesful to allow TCP/IP communications with a remote destination. Returns: 0=Fail / 1=OK | |
Return |
SocketClose |
Closes the current socket connection | |
Return |
AcceptOpen |
Return |
AcceptClose |
Return |
Initialise |
Return |
Listen |
Port |
Return |
SocketOpen |
Return |
SocketClose |
Return |
AcceptOpen |
Return |
AcceptClose |
Return |
Initialise |
Return |
