Component: SRF (WirelessThings) (SRF) (Wireless)
Revision as of 15:16, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Wireless
SRF (WirelessThings) component
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. It has an on-board balun and chip antenna, which can be detached for applications where an external antenna is required.
Please click here to view the component source code (Beta): FC_Comp_Source_SRF_Component_v2.fcfx
SendString
Send a string of data using the SRF Module
- STRING Data
Wake
Wake the SRF module. Includes a 10ms delay to allow radio to wake.
SendChar
- INT Char
Sleep
Sets the SRF module to sleep mode. (Includes a 10mS delay to allow any data to finish sending)
SRFInitialise
Initialise the SRF Module. Activate device through 'enable' pin, and wake device to ensure it is not sleeping.
ReceiveString
- BYTE Timeout
- BYTE NumBytes
- STRING Return
ReceiveChar
- BYTE Timeout
- INT Return
Sleep Mode (ATSM)
Defines which sleep mode will be used when calling the Sleep component macro.
Serial comms data rate specified in bits per second.
Onboard UART peripheral to use to perform serial commands. Software mode available but not recommended for receive applications unless combined with a pin interrupt.
TX
Serial data transmit pin, output from the target microcontroller and should be connected to the RX pin of the module.
RX
Serial data receive pin, input to the target microcontroller and should be connected to the TX pin of the module.
Sleep
Data Source
Simulation data source used to allow the component to connect to COM port hardware or the the data API components.
COM Port
Lists all the current available COM port hardware on your PC.
SendString
- STRING Data
Wake
SendChar
- INT Char
Sleep
SRFInitialise
ReceiveString
- BYTE Timeout
- BYTE NumBytes
- STRING Return
ReceiveChar
- BYTE Timeout
- INT Return
Sleep Mode (ATSM)
TX
RX
Sleep
Data Source
COM Port
