Component: USB Slave (Comms: USB)
Revision as of 15:17, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.3
Category Comms: USB
USB Slave component
Component to create and communicate using a generic USB communications profile. Has the ability to allow the device to be a slave to the PC. Compatible with simulation and USB enabled microcontroller devices (PIC/dsPIC).
Please click here to view the component source code (Beta): FC_Comp_Source_USBSlave.fcfx
SendString
Adds a string of bytes onto the end of the outgoing data buffer.
- STRING Data
Data String To Send
- BYTE Length
Max number of bytes to try and add to the outgoing buffer.
GetString
Retreives a string of data from the incoming data buffer starting from location 0 and incrementing up to the NumBytes parameter.
- BYTE NumBytes
Specifies the maximum number of bytes to try and read.
- STRING Return
RunSlaveService
Stalls the microcontroller and waits for an incoming message from the USB, when a message is received the macro defined in the USB Slave properties is automatically run. While the macro is running you can choose to send data back to the PC if you wish.
SendByte
Adds the byte onto the end of the outgoing data buffer.
- BYTE Data
Data byte to transmit to the host
SendByteArray
Adds an array of bytes onto the end of the outgoing data buffer.
[[File:]] - Data
Data Bytes To Send
- BYTE Length
CheckRx
Called to check if there is any incoming data waiting to be received. Returns the number of incoming data bytes. Only needed when not running the slave service.
GetByte
Retreives the byte at location Idx from the incoming data buffer.
- BYTE Idx
Specifies the location in the incoming buffer
StopSlaveService
Allows the microcontroller to leave the stalled slave mode and resume its normal independant functionality. Must be called from within the slave service routine to work correctly.
Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout.
USB Properties
Vendor ID
USB VID
Product ID
USB PID
Device Name
USB Device Name
Manufacturer
USB Manufacturer
Major Version
USB Major Version Number
Minor Version
USB Minor Version Number
Enumeration Timeout
Specifies if the enumeration (Initialise function) can timeout if taking too long.
Country Code
Country code used by some regional based USB devices
Maximum Current (mA)
Maximum amount of current the USB host will provide before shutting down the USB channel.
Slave Macro Properties
Slave Macro
Flowcode macro to call while the slave service is enabled
Macro Parameters
Defines the parameters for the slave service macro allowing data from the host to be automatically passed into the macro.
USB Driver
Driver Directory
Directory to save the generated device driver .inf file
Driver Filename
Filename assigned to the USB device driver .inf file when generated.
Generate Driver
Generates a driver file when set to Yes, Automatically jumps back to No when complete.
Instance
Hardware instance to communicate with any connected USB slave devices.
Timeout (ms)
Simulation host to slave communications timeout in milliseconds
Text displayed on the I/O flasher comms component.
SendString
- STRING Data
Data String To Send
- BYTE Length
GetString
- BYTE NumBytes
- STRING Return
RunSlaveService
SendByte
- BYTE Data
SendByteArray
[[File:]] - Data
Data Bytes To Send
- BYTE Length
CheckRx
GetByte
- BYTE Idx
StopSlaveService
USB Properties
Vendor ID
USB VID
Product ID
USB PID
Device Name
USB Device Name
Manufacturer
USB Manufacturer
Major Version
Minor Version
Enumeration Timeout
Country Code
Slave Macro
Macro Parameters
USB Driver
Driver Directory
Driver Filename
Generate Driver
Instance
Timeout (ms)
