Component: WLAN (ESP32) (Comms: Networking)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 2.4 |
Category | Comms: Networking |
WLAN (ESP32) component
Wireless LAN component designed to work with ESP32 modules
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP32.fcfx
ReadIPString |
Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1" | |
Return |
SocketConnect |
Address |
Port |
Return |
SocketListen |
Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail | |
Port |
Return |
ReadSSIDFromScan |
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first. | |
Index |
SSID Index | |
Return |
SocketWrite |
Buffer |
Size |
Return |
Disconnect |
Attempts to disconnect from the SSID. | |
Return |
SocketOpen |
Returns 1 if socket sucessfully opened | |
Return |
SocketClose |
Return |
Uninitialise |
Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not | |
Return |
AcceptOpen |
Returns 1 if there is an incoming connection on the listening port | |
Return |
SocketRead |
Buffer |
Size |
Return |
AcceptClose |
Close the socket associated with the Accepted incoming connection | |
Return |
Initialise |
Initialise the WiFi system Returns 1 if successful Returns 0 if not | |
Return |
Properties |
Verbose Debug |
Simulation |
Network Interface |
List of network interfaces connected to the PC. Sets which interface we are communicating via. | |
Console Data |
Generate Console Data |
ReadIPString |
Return |
SocketConnect |
Address |
Port |
Return |
SocketListen |
Port |
Return |
ReadSSIDFromScan |
Index |
SSID Index | |
Return |
SocketWrite |
Buffer |
Size |
Return |
Disconnect |
Return |
SocketOpen |
Return |
SocketClose |
Return |
Uninitialise |
Return |
AcceptOpen |
Return |
SocketRead |
Buffer |
Size |
Return |
AcceptClose |
Return |
Initialise |
Return |
Properties |
Verbose Debug |
Simulation |
Network Interface |
Console Data |
