Component: RGB Xmas Tree (Misc Circuit)
Revision as of 15:17, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Misc Circuit
RGB Xmas Tree component
Component complete with macros and simultion to drive the MatrixTSL RGB Xmas Tree decoration.
Please click here to view the component source code (Beta): FC_Comp_Source_XmasTree.fcfx
For more information please refer to the Xmas Tree blog post.
PlayNote
Plays a specific note for the length of time specified.
- BYTE Note
0-59 - 0=C, 1=C#, 2=D, 3=Eb, 4=E, 5=F, 6=F#, 7=G, 8=G#, 9=A, 10=Bb, 11=B, 12=C...
- UINT Length
WaitAudio
Checks to see if the audio circuit is current outputting a tone. If it is then the macro will wait until the audio is free again.
- UINT Delay
Optional ms delay after the audio has stopped playing 0=No Delay
SetColours
Generates a colour value based on the input colour parameters and asigns it to all of the LEDs.
- BYTE Red
Red 0=None, 255=Max
- BYTE Green
Green 0=None, 255=Max
- BYTE Blue
Blue 0=None, 255=Max
RandomLED
Randomises the colour to a specific LED
- BYTE LED
LED 0 to NumLEDs - 1
MoveToColour
Generates a colour value based on the input colour parameters and transitions one of the LEDs to the new colour. Remains in the function until the new colour has been reached.
- BYTE LED
- BYTE Red
Red 0=None, 255=Max
- BYTE Green
- BYTE Blue
- UINT TransistionDelay
Delay in milliseconds between each transition
SetLED
Directly sets the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE LED
- BYTE Colour
JingleBells
Plays the Jingle Bells tune using the audio driver.
SetLEDs
Sets the colour of all the LEDs. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE Colour
CheckSwitch
Checks to see if the switch is pressed. Returns 1 to indicate a press and 0 to indicate not pressed.
SetColour
Generates a colour value based on the input colour parameters and asigns it to one of the LEDs.
- BYTE LED
- BYTE Red
Red 0=None, 255=Max
- BYTE Green
- BYTE Blue
CheckAudio
Checks to see if the audio circuit is current outputting a tone. Returns 1 to indicate audio active and 0 to indicate not active.
RandomLEDs
Randomises the colour of all the LEDs
GetLED
Directly read the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE LED
Starts up the LED PWM and Audio software driver.
Pin Connections
LED Data Port
LED Clock Pin
LED Enable Pin
Audio Output Pin
Switch Input Pin
LED Properties
Number Buffers
Number of octal buffer IC's you will require to drive the LEDs. Note that the microcontroller data port provides the first buffer so the numbr of ICs is actually one less than the value shown.
Number LEDs
Test On Startup
Performs a simple LED test routine on start up. LEDs should all light up white, red, green and blue in second intervals.
PlayNote
- BYTE Note
- UINT Length
WaitAudio
- UINT Delay
SetColours
- BYTE Red
Red 0=None, 255=Max
- BYTE Green
- BYTE Blue
RandomLED
- BYTE LED
MoveToColour
- BYTE LED
- BYTE Red
Red 0=None, 255=Max
- BYTE Green
- BYTE Blue
SetLED
- BYTE LED
- BYTE Colour
JingleBells
SetLEDs
- BYTE Colour
CheckSwitch
SetColour
- BYTE LED
- BYTE Red
Red 0=None, 255=Max
- BYTE Green
- BYTE Blue
CheckAudio
RandomLEDs
GetLED
- BYTE LED
Pin Connections
LED Data Port
LED Clock Pin
LED Enable Pin
Audio Output Pin
Switch Input Pin
LED Properties
Number Buffers
Number LEDs
Test On Startup
