Component: API UART Dummy (API Slave Devices)
Version | 2.0 |
Category | API Slave Devices |
API UART Dummy component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_API_UART_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_UART_Dummy.fcfx
UARTCheckRX |
Check to see if the UART module has received any data | |
Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
Return |
UARTInitialise |
Initialise the UART module ready for communications | |
Channel |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-53 | |
State |
Range: 0-1 | |
Return |
IOGetInputPin |
Sets the selected digital pin to an input and reads the input state. | |
Pin |
Range: 0-19 | |
Return |
UARTReceive |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
Channel |
Return |
UARTSend |
Send a byte via the UART module | |
Channel |
Data |
Data Byte to send. Range: 0-255 | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
Properties |
UARTCheckRX |
Channel |
Return |
UARTInitialise |
Channel |
Return |
IOSetOutputPin |
Pin |
Range: 0-53 | |
State |
Range: 0-1 | |
Return |
IOGetInputPin |
Pin |
Range: 0-19 | |
Return |
UARTReceive |
Channel |
Return |
UARTSend |
Channel |
Data |
Return |
Initialise |
Return |
Properties |
UARTCheckRX |
Channel |
Return |
UARTInitialise |
Channel |
Return |
IOSetOutputPin |
Pin |
Range: 0-53 | |
State |
Range: 0-1 | |
Return |
IOGetInputPin |
Pin |
Range: 0-19 | |
Return |
UARTReceive |
Channel |
Return |
UARTSend |
Channel |
Data |
Return |
Initialise |
Return |
Properties |
